Ga door naar hoofdinhoud
De Nikon D5200 is een F-vatting DSLR-camera met een 24,1-megapixel DX-formaat CMOS-afbeeldingssensor. De D5200 heeft een maximale resolutie van 6000x4000 en is in staat tot het opnemen van 1080p-video.
My camera just died!
I've fully charged my battery and when I try to open it, the green light flashes (as normal) but it doesn't open and when I see in the view finder, it indicates that it hasn't charged and the battery is empty even though I've just fully charged it.
P.S: I've tried another battery and it's the same
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
have you tried using another charger to charge the batteries and checking the voltage levels in the batteries to see if they are actually charged. It could well be that the mains charger is faulty and not charging the batteries properly.
Was dit antwoord nuttig?
2 opmerkingen:
I've tried it and it's the same
door
my next advice would be to open the camera up and check the solder joints on the battery contact and motherboard side contacts, sorry there isn't a guide available on how to do this but the D5100 and D5300 are both similar cameras and open up pretty much the same way, so follow the guides on how to open those cameras as best you can.
door
If restoring camera to its default factory settings will fix this issue then its ok, otherwise visit Nikon D5200 Manual to proceed another solution.
To restoring Nikon D5200 to its factory settings, just hold down the [Menu button] button and the [Information button] button together, until the control panel turns off briefly while the camera resets itself to the factory default settings.
Voeg je antwoord toe
Mustafa Hmood zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 1,491
