Ga door naar hoofdinhoud
Also called the Crosley Musician Entertainment Center.
Why does the record player play slowly
the record part of this machine plays the records slightly slower than they should be played. I am curious if there is a repair option for this, and where to look? Thanks.
Is dit een goede vraag?
1 Opmerking
I just saw this post! This was my issue as well. Thank you!!!!
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
I had this same problem. Turns out that I didn’t have the lid open fully abd the vinyl was rubbing slightly on the lid!
Was dit antwoord nuttig?
Score 2
1 Opmerking:
You are amazing thank you so much I was literally freaking out over this. Super helpful my guy thanks again
door
I'm not sure how old yours is, but I'm guessing since it has a disc player it's pretty new. I have a different brand player, produced in the last ten years, that slows down often. To adjust the timing on it there is tiny mechanical part on the inside that you can insert a jewelers flat head into and lightly turn to adjust the timing. I usually pull up a song on YouTube and use it to compare to the record. However if you adjust it while a records on you risk scratching.
Mine slowed down so often I drilled holes in the bottom to access it without tearing the player apart everytime just to adjust it. After all I can't listen to The Bee Gees slowed down
-Liz
Here's an image of the part, I have three, one for each speed.
Score 1
1 Opmerking:
no only a motor underneath. no place for adjustment. sad
door
Your belt underneath the platter is either stretched or slipping.
Voeg je antwoord toe
Dan Strickland zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 64
Altijd: 12,128
