Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Vragen Bekijk alle
Why does the phone hit random buttons while in-call?
Hey guys!
I figured I put this question out there but recently got a request to repair a blue iPhone 5c and the phone works fine, tower during calls as well at just in random occurrences, the phone will randomly continue to hit buttons like speakerphone or open apps. The home button has been replaced and the battery was replaced to my best knowledge. Any idea what it could be?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
If there are random button "pushes" during calls, then it sounds like the proximity sensor is not working. Was this device repaired recently or has it just started happening out of the blue?
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Its been happening for a little bit. a month or two from what my client tells me.
door
I agree with what Minho has said. The Proximity sensor is the sensor near the top of the phone that tells the screen when to turn on or off during a phone call. This can also be tested with siri. The next time you are in a call try covering up the top half of the phone and see if the screen shuts itself off. If not this is a sure sign of a failing or nonworking proximity sensor.
1 Opmerking:
Okay, I'll give it a try and see if that works
door
Voeg je antwoord toe
David Loder zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 8
Altijd: 1,143
