Ga door naar hoofdinhoud
Uitgebracht in mei 2012 en geïdentificeerd met modelnummer CE657A#BGJ. De HP LaserJet P1102w is geschikt voor USB- en wifi-verbindingen.
Why does it not print correctly
Hello. I have an HP Laserjet P1102w that prints clearly but whenever it prints the prints comes out in a slant way. I seem not to understand whats going on with the printer. I have cleaned the head and changed the toner but its the same result. I'm hoping I ll be able to find an answer here.
Is dit een goede vraag?
Score 1
1 Opmerking:
Hi, Not trying to be smart, but have you checked that you are not printing whatever font you are using in "italics"?
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
I have several clients that have the same printer… usual fix is totally delete the printer. remove the USB cable, reboot and then see if the printer still shows. if yes again do a uninstall and remove from device & Printers. so that when you reboot you have NO PRINTER… then shut off computer, plug in printer cable. start computer and follow any instructions. it should AUTO start to install Printer.
Was dit antwoord nuttig?
Voeg je antwoord toe
shobenboy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 711
