Ga door naar hoofdinhoud
Reparatiehandleidingen voor de "Mini"-serie netbooks van HP, compacte computers met een kleine vormfactor.
HP EliteBook 8460p Wifi Issue
Hello Everyone. I have a Notebook HP EliteBook 8460p. I installed windows 10 in it few days ago which worked perfectly fine. The wifi was working fine too. But because i could not run a software in windows 10, i had to install windows 7. In windows 7 it wasn't showing any wifi names or infact the wifi column. In the control panel also there was no wifi adapter showing. I installed another windows 7 but it was the same problem. I downloaded drivers from HP website but they could not be installed because of some error. I tried connecting the laptop through lan cable but it did not connect again as well. It wasn't showing any connection. I installed windows 10 again, and the wifi problem is gone. Can you guys please help me how can i fix this wifi issue in windows 7 because I have to run a software that is compatible with windows 7 not 10. Thank you so much guys.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Start task manager using code ctrl + alt + delete
Then click on more details or show other processes
Then search for Service Host ( Network Restricted )
End these 3 4 tasks
PC will show crash and restart
And network issue will be solved after restarting
Was dit antwoord nuttig?
Voeg je antwoord toe
Shantanu Bansal zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 1,047
