Ga door naar hoofdinhoud
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
Identify broken contact pad in charging port
Hi, I have this motherboard that has a broken contact pad where the charging port is soldered. I wanna try a jumper if its possible, but I am not sure where I should solder the jumpler wire to.
Look at the picture, from the botton up is the fourth contact pad that is missing.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
That pad looks like a ground to me. See the large blue trace? Thats usually a ground plane. Just bridge the pad that is left to the ground or put a jumper between 1 and 3 off what is left of trace. 4 and 5 look common as well. Use flux as solder wont stick as your working with it well.
Was dit antwoord nuttig?
4 opmerkingen:
Thanks for your reply, I just edited my question, I wrote third, but is actually the fourth one that is missing.
door
Since the charging port you can buy the whole daughter board separately I personally would just stock up on these charging ports.
door
My bad, didnt paid attention I had selected s4, the motherboard is from a SIII, the GT-I9300I. So, I don't have the option to replace just that part.
door
I soldered the port back and didn't solder a jumper yet. It charges well, and connects to the computer well, too. I am still wondering what that pin is for, I guess it might be ground after all. However, in the picture Ben shared, it goes somewhere else.
door
Het nuttigste antwoord
Does this help?
http://www.mobilerdx.com/wp-content/uplo...
Score 2
1 Opmerking:
Thanks a lot Ben. I was looking for something like that.
door
Voeg je antwoord toe
marvmen21 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 447
