Ga door naar hoofdinhoud
Het vlaggenschip van Huawei uit 2016. Voorzien van een unibody-behuizing en een dubbele camera achteraan, ontwikkeld in samenwerking met Leica. Verkrijgbaar met 32/64 GB opslagruimte en in zes verschillende uitvoeringen. Modelnummers EVA-L29, EVA-L19 en EVA-L09.
touch screen not working after screen replacement?
Hi everyone! i have a big problem. I've just replace the screen of my huawei p9 (it has been a VERY HARD work), when i've finished all, i connect all the cable, i turn on the phone, the screen work but the touch screen doesn't. What happen? how can it not work? i've done everything right...
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Filteren op:
hi, have you solved? Did you understand what the problem is?
I have the same problem and I am very worried because the phone is not mine but my brother and he is convinced that the touch screen does not work because I have not been able to fix it. I do not want problems with him. Please reply
Was dit antwoord nuttig?
Resurrecting something from the dead here but I’m seeing issues with a P9 myself. Touch is working but occasionaly unresponsive to swipes (especially left-to-right) or misinterprets swipes as touches.
Googling leads me to believe there’s a grounding problem or something. Or perhaps the part is just bad. I’ll try insulating the screen from the frame and clean the pressure contacts to see if it helps and update this with any new info.
1 Opmerking:
Hi... Any update?
door
Voeg je antwoord toe
apriliamx5535 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 38
Altijd: 2,355
