Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Vragen Bekijk alle
Home button not working but Touch ID does
Hello,
I've got a weird issue after a screen replacement: my home button doesn't work even if Touch ID does. I tried to install a replacement home button but the problem wasn't solved (and obviously the replacement button did not support Touch ID). What could be the problem? I thought about the flex cable that connects the button to the motherboard but if that was the problem even Touch ID should not work.
Thank you!
Walter
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Logically, you would expect the Home button action to work if the Touch ID works. The usual question is normally the opposite situation.
In your case, there could still be damage on the extension flex that runs beneath the backlight shield. Just think of it as a highway with multiple lanes. If the Home button lanes are damaged but the others are not, then you would see similar symptoms. You should inspect it closely and test continuity on each pin to be certain.
The other possibility is in how you are re-assembling the home button, specifically the backplate (iPhone 6 Plus Vervanging van de thuisknopmodule). this is what the "button" presses against. If it isn;t making solid contact, the the button press will not be noticed.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
Well, I guess the problem was indeed the flex cable. Thank you for your answer and detailed explanation!
door
unplug the charging port and battery and it should fix the problem
door
iPhone 6.
Touch ID works, home button doesn’t.
I changed the suspected part - flex cable. Problem not solved.
Now, I changed the home button, and found that new home button is working, but at the cost of Touch ID.
Have anyone incurred a similar problem before. If so, what is the solution.
1 Opmerking:
yes i have with the seven and the five s just unplug the battery and the charging port and it should work , i think the update is the issue
door
Voeg je antwoord toe
Walter Simoncini zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 9,266
