Ga door naar hoofdinhoud
The Keystone KSTAD70A 70-pint Dehumidifier removes up to 70 pints of humidity from the air per day.
Reconnect float in collector tank
I dropped the collector tank and the float came out. Reconnected it with the male pin on the float into the opening on the collector. Can't figure out, however how to make the other side stay in place. Can't find the shroud or whatever that held it loosely in place to swing. So now the machine always thinks that the tank is full and therefore won't run. Any help?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
There should have been a little plastic piece on each end to fit into holes. Do you think one of them broke off?
Mine just broke and I'm searching for a place to buy a replacement piece
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Michael Folloni zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 90
