Ga door naar hoofdinhoud
Repair guide and troubleshooting information for Apple wireless mouse with multi-touch support. Model number A1657 or A3204.
The top casing feels "loose", any way to fix it?
Ever since i got my Magic Mouse 2, the top plastic casing has felt kinda "loose" and a bit wobbly, so every time i loosely click it or run my fingers over it, it does not feel good.
Is there any way to fix this, apart from buying a completely new one?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@erikeia, Erik Eia , Ifixit rated trying to repair this mouse a 2 out of 10. From the link #1 below you can see the tear down, to see if you want to attempt to open the mouse and see if you can repair loose /wobbly case. If the top is just a little loose from the bottom you could try a little fast setting gel glue at the seam. Link #2 is just an example of glue that may be used. make model # and your complete question, so we at Fixya can answer your question effectively.
Magic Mouse 2
http://www.gorillatough.com/gorilla-supe...
Was dit antwoord nuttig?
Score 6
1 Opmerking:
I´ll see, thx
door
Voeg je antwoord toe
Erik Eia zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 54
Altijd: 4,999
