Ga door naar hoofdinhoud
The Sprout Channel Cubby™ was first produced in 2014, it is a child friendly device that provides the functionality of a tablet. It boasts a 1024x600 touch screen, Two 2 megapixel cameras (one rear facing and one front facing), Parental controls and security, HDMI connectivity, Bluetooth, WiFi, 16GB Memory, 1GB RAM, and a 1.2 Ghz processor. It has access to internet and various application stores and applications, which can be limited by the parental controls
29 Vragen Bekijk alle
sprout channel cubby with broken screen
it turn white with black and wont turn back normal
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
danielgaming99999, Go to the 1st link below sprout channel cubby support and use the instructions to reset/restore your device. If that does not help, chances are you will need new/replacement digitizer/screen for your sprout channel cubby. 2nd is a guide to show how to replace the digitizer/screen and the 3rd link shows replacement part, which you can also google search for better pricing. Good luck.
http://sproutchannelcubby.com/tech-suppo...
Sprout Channel Cubby Digitizer Replacement
https://www.amazon.com/Replacement-Displ...
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
danielgaming99999 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 632
