Ga door naar hoofdinhoud
The 2013 edition of Razer's 14" ultralight gaming laptop. Released in July 2013 with the model numbers RZ09-01020 or RZ09-01021.
My screen is not working
When i switched on my laptop, the screen is malfunctioning as it splits into three different screen on the laptop. Is there a way to fix it myself?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@susu23 first you want to make sure that it is your LCD. Connect an external monitor and see what that shows. Should that show the same defect as your laptops LCD then you know that you are having a GPU (motherboard) issue. If the external shows a normal image, consider replacing your LCD. Take a look at this guide and this video. Combined you see how to remove and replace the LCD.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Susu zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 732
