Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
Logic board repair or soldering?
Hello everyone. I have changed my logic board in my 5s and my old one had bent connectors on the logic board so the home button/power etc cable won't connect.
How can I fix this? Can I solder it onto the bent pieces?
Is dit een goede vraag?
Score 1
2 opmerkingen
Send it to @jessabethany at iPad rehab, she can fix everything.
door
@gigabit87898 change your personal preference in your answer to a more objective one. Not sure how many boards you have send of to get fixed, but your answer only describes one source and there are plenty others. You are also needing to know the location. for example when in Canada, send it to @refectio etc. How about Australia (got some good people down there as well)... I am sure you get what I mean.
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
No the connectors have to be replaced entirely.
Was dit antwoord nuttig?
Score 5
U need a microscope.
U can repair or change it if you have the right tools and a good experience with microsoldering. This is not easy work, they actually need great patience and skill. If you wanted to learn something better start to repair now and if not you better send it to micro solderer like @jessabethany or somebody else near u.
It is much cheaper to buy a second hand logic board for the 5S instead a repair. Here in the Netherlands you can buy these for arround €50,-
Voeg je antwoord toe
Benito Graffagnino zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 163
