Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Vragen Bekijk alle
iPhone screen black, makes charging sounds when plugged in
I dropped my iphone 5 on the floor. Now the screen is black, but it makes charging sounds when i plug it in. When not plugged in, the phone does not respond at all.
I know this can be because of a broken lcd, and I consider replacing the screen. But does the fact that the iphone only makes sounds when plugged in mean I should also try to replace the battery?
Anything else this could be?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
@tstone it is supposed to make that sound when it gets plugged in. Since you are going to have to replace the display assembly (that is what failed when you dropped the phone)and thus open your phone,might as well replace the battery. That way you only have to open it one time.
Was dit antwoord nuttig?
Score 2
It may be worth just opening your phone to check that the lcd or digitiser connectors have not come out of their sockets.
Voeg je antwoord toe
Torstein zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 15
Altijd: 207
