Ga door naar hoofdinhoud
Released September 2014, the LG G3 Vigor is smaller and cheaper than the LG G3.
Phone will or load pass beginning screen
My phone locked up on me, so I took the battery out. When I turned the phone back on it now won't load pass the beginning LG screen. How can I get it back on?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Try holding the power button and the volume down button . when you get the android use the volume buttons to scroll up or down and select boot normally then press the power button to select . This should allow the phone to boot normally. If this gives no joy then try resettng the phone to factory settings . Please understand that you will loose all data you have on the phone , contacts, photos ,music, apps will all be gone . It will be the same as when you first got the phone. Hope this helps
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Susan Sells zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 76
