Driver for Windows 10?
Is a driver available for Windows 10.2?
Is dit een goede vraag?
Hi,
HP ended driver support for your printer with Windows Vista.
You could try installing the Vista drivers in Windows 10 using Compatibilty mode and see if that works.
When you have the Vista driver software ready to be installed right click on the setup file and select Compatibility mode and then select either Vista (if available) or Win 7 and follow the prompts. See if it works after the install is complete.
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 14
Altijd: 1,546
