Ga door naar hoofdinhoud
The Toshiba Chromebook 2 laptop was released in 2014, and the model number is CB35-B3340. This Toshiba Chromebook is silver with a 13.3" high resolution screen.
Are replacement keyboard/top cases compatible across different models?
I have a Toshiba Chromebook 2 2015 with a Canadian English keyboard, and would like to replace it with a USA keyboard (the enter key bothers me as I am used to the enter key of the USA version.)
My question is- do I have to buy a keyboard/topcase specific to the Toshiba Chromebook 2 2015, or can I use one from the previous Toshiba Chromebook 2 model?
All the Toshiba Chromebook 2 models look physically identical, so I imagine this would work. I understand I would be losing the backlit keyboard feature if I did so, as I would just like the cheapest replacement possible.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hi!
You can try???, just keep in mind not to damage the new keynoard if you need return it. Just make sure that the connections, size and shape are the same before you buy it...
Was dit antwoord nuttig?
Voeg je antwoord toe
madmaxmedia zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 168
