Ga door naar hoofdinhoud
D1760-2 DECT 6.0 Cordless Home phone with caller ID.
Answering machine full how to delete messages
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
@unrea , Paul. link below will explain how to delete 1 message at a time or delete all. 2nd link is Uniden support for you manual. Good luck.
https://www.techwalla.com/articles/how-t...
https://www.uniden.com/product-informati...
Was dit antwoord nuttig?
Score 3
5 opmerkingen:
It said mail box is full but it's not what do i do to fix it
door
I also have an answering machine that says mailbox is full but it is not and has no messages. Nothing to delete. Can you help?
door
@sfognano
What is the make and model number of the phone with the answering system?
door
After you listen to all your messages, the message icon turns off and the
charge LED on the handset stops blinking. If it doesn’t, you can reset it:
With the phone in standby, open the menu and select Global Setup; select
VMWI Reset, then select Yes.
door
THANK YOU …..Stopped blinking
door
I do NOT have a so-called Delete button on my Uniden that I inherited with this apartment. I am so frustrated at having 32 old messages - and no telephone customer support service available from the manufacturer - that I am about ready to open my back door and pitch it into the woods!
Update (07/28/2020)
And my GOD! that worked! When I typed that in, I was able to actually find a reference guide online .... you hit the button on the bottom of the base that looks like an arrow ... when the message plays back, you hit the zero with the line through it. Altho the sound was a piercing electronic squelch that probably disturbed the animals, it did go fairly quickly! PROBLEM SOLVED! Ok, not tossing the phone out the door ;)
Score 1
4 opmerkingen:
@sparkle4jesus
What is the model number of the phone?
door
Jayeff , that's a good question ;) All I know is it says Dect 6.0.
door
@sparkle4jesus
So there is nothing else printed on the phone somewhere, under the battery perhaps or in /under the charger cradle then? That's very strange
door
Didn't think about that! I flipped it over and it says DECT2080-2
door
For Vtech LS 6245 you cannot delete all new messages, but can delete all old messages. So the fastest way to delete all messages that are new is to
1) Listen to messages
2) Skip them all with the forward button, this can be done faster than deleting each individual one
3) Go in to the answering machine menu and delete all old messages, it will now delete all the messages you just skipped :)
Y K
Voeg je antwoord toe
Paul kellock zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 63
Altijd: 17,065
