Ga door naar hoofdinhoud
Hewlett-Packard begon in 1993 met de productie van laptops.
3324 Vragen Bekijk alle
Is my HP Probook 4510s over heating?
Hey, i have three problems with my HP ProBook 4510s.
1) After periods of time with extensive gaming use of my laptop, it randomly shuts down in an instant without warning. I was wondering if this is due to over heating? i looked up google stuff to see if i could find a way to open this laptop to check if there is extensive amount of dust inside, but i fail to be able to find a way in. Also just after it shuts down, the base is extremely hot.
2) If my screens brightness is set to around 50% or higher, the laptops back light turns off. everything is still running because i can only just see it in some lights, but otherwise i cant see anything.
3) If the battery is not at 100% and i go to play a game, the same as problem 1 occurs with the instant-no-warning shutting down. This problem does not occur at 100% battery or when no battery is connected.
Other this i have noticed:
About twice the laptop basically coughed... yea, dust came out in splutters, it was relay weird and made me jump. LOL.
Problem 2 can be fixed if i connect an external monitor to my laptop.
I find it pointless using my external laptop fan when the air goes up, seeing that the laptops vents are on the side.
Thanks in advance! :)
Elliot
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Here is the service manual that may help you to get it cleaned out http://www.keepandshare.com/doc/2469492/... as for the rest of your issues. it does sound like a battery issue to me. Possible not holding a complete charge. That is why you probably do not have the problem when you are on AC power. I would think a new battery would help out. But of course those are just my 2 cents....good luck and let us know.
Was dit antwoord nuttig?
Score 2
Ok guys, I've found out that problem 1 was now related to problem 3 the whole time! didn't realize the battery wasn't at 100% >,<
since its been 100% it hasn't crashed at all! still wondering if anyone can lend some advice on 2 and 3 then please.
1 Opmerking:
What did you do to resolve problem 1? I have been having the same issue.
door
Voeg je antwoord toe
Elliot zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 6,118
