Ga door naar hoofdinhoud
Uitgebracht in augustus 2010. Geïdentificeerd door onderdeelnummer: 884354009250.
I need some Button Turn off/on
Is dit een goede vraag?
Score 5
2 opmerkingen:
I have the same problem, the button fell out. I have the button but there seems to be something else that is missing because the button doesn't work. when placed back, it's loose. Did you fix it?
door
I also have this problem. Anyone?
door
Voeg een opmerking toe
1 Antwoord
Sometimes my H1 loses the date and time. When it does that, it will not record. The unit turns on but pushing the record button does nothing.
I turn it off, hold down the Record button while powering the unit back on. It then defaults to the date. Use the forward or backword buttons to get to the correct date or time. Use the Play button to set the time after you choose the correct time.
Every time I reset the date and time it makes the Record button work. Try it and answer back.
Was dit antwoord nuttig?
Voeg je antwoord toe
Cio Fadhilah zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 23
Altijd: 1,435
