Ga door naar hoofdinhoud
How do you fix the Clock reset problem?
I need to reset the clock after each power-down.
I am sure I need a pram battery, just not sure which one:
The 3v lith coin cell, or the:
The G4 Titanium Mercury PRAM Battery @ $39.95
Product code: IF121-017-1
Apple Part #: 922-436
Do I need to open up the case to see which one?
Thank you.
DC
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Your PRAM battery needs to be replaced. It appears to be part number 922-5205 for the PB G4/DVI 667. Here's Apple's guide on which battery you need: http://support.apple.com/kb/ht2295
Was dit antwoord nuttig?
Score 2
You must know
the exact specifications of your PowerBook.
PowerBook G4 (15-inch FW800) & PowerBook G4 (15-inch 1.5/1.33GHz) 922-6007
PowerBook G4 (15-inch 1.67/1.5GHz) 922-6714
Powerbook G4 (15-inch Double-Layer SD) 922-7173
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
Score 1
Voeg je antwoord toe
Crocdog zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 23
Altijd: 1,971
