Ga door naar hoofdinhoud
Apple's 6th revision to the iPod Touch lineup, released in July 2015.
149 Vragen Bekijk alle
iPod 6 Gen Screen Replacement
I have an ipod 6 Gen with a cracked screen. It works fine so I assume it's just the top layer of glass. Is it possible to replace just the glass and not the entire lcd screen? Also, I haven't been able to find a replacement glass part or lcd screen. Does it use the 5th Gen Lcd? I'm in Canada if anyone can point me in the right direction. Thanks!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
C Smith, It appears the assy. is advertised for 5/6 generation so I would imagine must be compatible. 1 st link is for display replacement instruction, other links are for display assy or just the glass to purchase, you can also do a google search to find more availability/pricing. Good luck.
iPod Touch 6th Generation Display Assembly Replacement
http://www.ebay.ca/itm/Replacement-Glass...
https://shop.icracked.com/collections/ip...
http://www.ebay.com/bhp/ipod-screen-repl...
https://www.aliexpress.com/popular/ipod-...
Was dit antwoord nuttig?
Score 4
Voeg je antwoord toe
C Smith zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 2,988
