Ga door naar hoofdinhoud
4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
331 Vragen Bekijk alle
gray "dead zones" after replacing screen
My iPod touch suffered a cracked screen, which I replaced thanks to the help this site provided. However, there seems to be an issue. If I open any app, I can see a series of small rectangular semi-translucent gray boxes on the screen, in something of a T formation across the width at the top, and along the length down the center. I have further discovered that these seem to be dead zones as far as touch controls are concerned, even though the display is showing.
Any thoughts as to what might be going on?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Try reconnecting the screen, and making sure there is no dust inside the connector (or the connector is bent).
Reconnect the old screen (if it was just cracked glass, working picture) to see if this is fine.
Was dit antwoord nuttig?
Score 1
if you put a new screen in, try to check to see if it was connected like it was before.
Voeg je antwoord toe
David Harvill zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 11
Altijd: 75
