Ga door naar hoofdinhoud
This is a, 35.70 cm (L) x 25.70 cm (W) x 2.54 cm (min H) / 3.96 cm (max H), notebook PC the unit weighs 6.6 lbs. It was released in 2006 and comes standard with a 80 GB hard drive.
6 Vragen Bekijk alle
Why does my cooling fan run so loud?
Every time I turn my computer on the cooling fan automatically runs very loud. It doesn't matter if there are no programs running or if I am streaming movies from the internet. I feel like the fan is going to blow up if this continues.
I have purchased a cooling base for my computer but it is still running hot. Do I need to use compressed air?
Please help before my computer explodes!!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
It sounds like there may be dust clogging the CPU or the fan itself, I'd recommend taking a look inside if you are able to
Was dit antwoord nuttig?
If your fan seems to be running slower than usual, or even making louder noises then you should check the fan to see if it is clear from any dust or debris. If there is dust then get a can of compressed air and and clear it out.
Here is a link to our troubleshooting age regarding this problem: HP Compaq Presario V6000
Voeg je antwoord toe
PJ Andress zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,052
