Ga door naar hoofdinhoud
Repair guides and support for the Acer line of netbooks including the Aspire One series.
How can I turn it on without using the power button
Power button not working. can I turn it on without the power button?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
On most of those computers, if you interrupt the power by pulling the cord and removing the battery, the computer will do a restart when the power and/or battery is replaced. That may get it going again. However, I have a feeling that your problem may not be the power button. Did you press and hold it for a few seconds?
Also, you could have had a bad battery for a time and then had a connection problem with the power cord. This could deceive you into believing the on-button was bad. Just some things to consider. The Acer may be old enough to have a bad battery by now.
Was dit antwoord nuttig?
Voeg je antwoord toe
rozlynadkins zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 87
