Ga door naar hoofdinhoud
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Vragen Bekijk alle
How can I determine the proper schematic and boardview
Schematics for this Macbook have various numbers, such as K24 and J30. I have done quite a bit of research, but have not figured out which schematic is correct. What am I missing?
Is dit een goede vraag?
Score 1
3 opmerkingen
Get the board number that's printed on the logic board. You'll have to open it up and inspect the logic board. It's usually 820-xxxx
Make sure not to get the number from the DC IN board a.k.a charging board.
door
Thank you for this. I had the board removed from the laptop, and did not see identifying characters that seemed relevant. I did see the characters on the DC in board. I will look again soon, Meanwhile things are working fine. Thank you, Ben.
door
I just opened the MLB. I saw this number before but discounted it because it did not correspond to any of the available schematics. It is MLB: C02107606N3DM6MAQ.
Am I just having a senior moment here....?????
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@terrycts check for the number as outlined in the attached image. Going by the model you listed as device, your board should be a 820-2936
Was dit antwoord nuttig?
Score 4
1 Opmerking:
It was in the vicinity you outlined. I expected white on black, but it is simply raised black. And the number is 820-2936! Thank you oldturkey03
door
Voeg je antwoord toe
Larry Hicok zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 3,148
