Ga door naar hoofdinhoud
The Dell XPS 10 tablet comes with Windows RT, Office Home and Student 2013 RT. Model number: XPS10-2727BLK.
My tablet is not charging, how should I fix it?
My tablet keeps on connecting and disconnecting when it is plugged to the charger.
What is the problem? And how to fix it?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The problem could be in one of the following elements:
  • Charger:
Try to plug the charger in another device to determine whether it is what cause the problem or not. If the charger is not working then you would have replace it. On the other hand, if it working then you might have
a problem with the charging port.
  • Charging Port:
Check on the Troubleshooting page for more information about a faulty charging port.
Was dit antwoord nuttig?
Voeg je antwoord toe
aljulanda almahfudhi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 592
