Ga door naar hoofdinhoud
AMD Athlon 64 X2 1.9 GHz processor, 3 GB of RAM and 250 GB hard drive. Also covered with a 56k modem, integrated Ethernet and Atheros 802.11b/g Wireless LAN.
4 Vragen Bekijk alle
Why doesn’t the webcam turn on?
Hi,
Is there a way for me to activate the driver or there is a button for me to turn on the webcam?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
The web cam cannot be turned on without a program to run it , skype for example or messanger , there may be a photo program in the laptop which will help you access the web cam but you'll have to find it . Heres a windows search with multiple web cam programs to select from
https://www.google.ca/search?q=webcam+ac...
Hope this helps
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
The webcam driver and hardware might be not compatible to your current version of Windows Operating System, due to automation upgrades of the laptop’s operating system. You will need to contact Toshiba or find the appropriate webcam driver from the link provided, http://support.toshiba.com/support/navSh...
Score 2
Voeg je antwoord toe
Sing Yang Cheng zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 439
