Ga door naar hoofdinhoud
The Dell Studio 1555 was released July of 2008 and discontinued May of 2011. The identification number is PP39L.
How do I fix a sticky key?
My spacebar will consistently stick when being pressed. It does not do this every time it is pressed and will eventually unstick after being pressed several times. How can I prevent this from happening again?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The possible cause for the spacebar to be sticking to the keyboard on the device could result of debris being stuck underneath of the key or being broken. If you follow the Dell Studio 1555 Troubleshooting page, it will provided a list of solutions on how to fix the problem along with a list of step by step guides to replacing the keyboard key.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Josh Boone zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 266
