Ga door naar hoofdinhoud
HD action camera released October 5, 2014.
sd card broke inside. Tried pushing it , only stuck more
broken sd card inside gopro. Tried pushing it but it's stuck good(bad)
Is dit een goede vraag?
Score 1
1 Opmerking
forgot to mention, I'd like to know where I could send it that won't "at our option" send me a refurbished one since this one hasn't been used.and Thank You.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
If it is no longer under warranty, you could try opening the camera using the Ifixit guide on how to replace the charging port to gain access to the SD Card reader and see if you can gently manoeuvre the broken card out.
Here is the link.
GoPro Hero 4 Black Charging Port Replacement
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Kevin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,350
