Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Touch Id not working after Screen Replacement
After I replaced my screen I got a message that popped up saying touch id unlivable for this device, the home button works perfectly fine but the touch id doesn't I tried to see if the connection was not secure but still nothing. I also tried to wipe the phone and restore it but still not working. If I replace the home button flex cable will it work again?
Update (10/26/2016)
Update I just ordered a Metal Plate with Heat Shield / Home Button Flex Cable Preinstalled i'll update if this fixes the issue
Is dit een goede vraag?
2 opmerkingen:
Also can I replace the LCD metal back plate with home button flex cable without effecting the touch id?
door
As I said, it is possible, my brother did it. But his Touch ID didn't work for a few days afterwards. I don't know why though, anyway, after that it worked just fine.
door
Voeg een opmerking toe
3 Antwoorden
Are you using the same button? If not, you will not be able to use Touch ID. It has to be the same home button, they are linked with the logic board.
Was dit antwoord nuttig?
5 opmerkingen:
Yes I am using the same button
door
...aren't you tired yet? do something productive.
Disgusting picture. get a life.
door
@darrell_wolfe me? what did i do?
door
@gigabit87898 Not to you. There was a troll here.
door
@tomchai okay, just wanted to make sure i didnt do something wrong :P
door
You have to find out by yourself, nobody know what you actually did during the repair so nobody know what exactly got damaged. If replacing the bridging flex did not work, you can be sure that it was not the cause.
The most likely cause might be when you pry the Touch ID button off, you bent the cable section too much. SMD ceramic capacitors are extremely suspecitible to chipping when bent.
2 opmerkingen:
is it just the home button that is linked to the logic board or is the bridging flex to
door
As I said, you have to find out yourself by elimination.
door
My brother had this issue once when he had to replace the metal plate of the LCD Display.
Touch ID didn't work for a few days, but suddenly without doing anything it worked again.
If you didn't change your Home Button, nor any other parts linked to the Touch ID, I'd wait a few days and then maybe think other solutions.
Voeg je antwoord toe
Jeffrey claro zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 163
