Ga door naar hoofdinhoud
De nüvi® 2689LMT is een GPS-apparaat dat in september 2014 door Garmin werd uitgebracht. Het kan worden geïdentificeerd aan de hand van het modelnummer 010-01188-02.
Why is my device not charging?
When I plug my charging adapter into my Garmin Nuiv 2689LMT and connect it to the car it is not powering on. What should I do?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Thanks for the question Allyson,
2 things bay be causing your issue:
The battery itself
The charger you are using.
Try it with a different charger, and/or take the device inside and plug it into the wall. If it works, it was your charger.
If the issue persists, it is most likely the battery. Luckily this is easy to replace with our guide, found here: Garmin Nuvi 2689 LMT batterij vervangen
Was dit antwoord nuttig?
Score 1
This answer is more than a year late, but hopefully it might help someone. The problem could also be the power jack located on the back of the unit. It is a mini-USB 5-pin jack. My Garmin worked on the internal battery but not when the power cable was plugged in! There does not seem to be a guide for this specific repair, but I am quite sure that a jack replacement guide for another Garmin nuvi model, for example 1490T, which uses the same jack, will provide sufficient guidance.
1 Opmerking:
Oops. I meant micro-USB, not mini-USB.
door
Voeg je antwoord toe
Allyson Smith zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 3,418
