Why is my camera saying "out of memory?"
My camera keeps telling me that my memory card is out of memory even though it is empty. How do I fix it?
Is dit een goede vraag?
@laney916 you did not tell us if you used the memory card in this camera before. You said that "it is empty" I assume that you have not used it. I would start by formatting it. Download your cameras manual from here. Check page 34 to start.
Was dit antwoord nuttig?
Yes, I have used it before and had no problems.
Did you try formatting?
I have had the camera for a couple years, no problems, Turned it on yesterday and after 2 or 3 pictures, it came up with out of memory. Tried other sim card, no help, formatted the sims, no help, emptied the camera and sims of about 10 pictures total. I get the same message with or without sims. What next?
I have the same issue as jim.. cool pix camera isn't detecting memory card. I tried several cards that I've used in the past and the camera is functioning as if there is no card inserted.
I'm having exactly the same issue, I bought a coolpix 5700 second hand. Used a few times, recharged batteries and inserted 2 brand new flash cards as said no memory. I even tried formatting but still nothing! Been googling then found this so can anyone please help
If its new camera and you don’t have a memory card inserted you will only be able to take 4 pictures and any additional picture after that you will get this message. Camera out of memory. So delete some of the 4 pictures and try again.
I figured out the issue everyone is having...
- I put the 16 GB Card in a few times making sure it got that "click" sound....
- Didn't Work...
- I Put the Card in again but this time it didn't "click"...
- I turned on the Camera it asked me to format the Card so I did and now it works just fine...
If you Slide the Card in all the way with "no click" and the Card stays there then Success!!
Hope this helps you all out...
- MonsterPianoPlayer : )
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 70
Afgelopen 30 dagen: 307
Altijd: 20,871
7 opmerkingen
Try taking out the memory card and then going to images. The camera might have a small inbuilt memory.
door Imad Knight
I had this problem and this is how I fixed it. Remove memory card and use the USB cable to hook the camera to your PC. Access the internal memory. I found a lot of pictures on the internal memory. I copied and save the pictures and then deleted them for the internal camera memory. I then reinserted my memory card and took some test pictures . The pictures were written to my memory card and the camera is now functioning properly!
door RJB
I have a similar problem but I'm using an iMAC ... how do I access the internal memory? Thanks
door Winn
I don't know about IMAC. On my Nikon L26 camera I just remove the memory card and attached the USB cable from my camera to my desktop PC and was able to access the memory using Explorer
door RJB
my nikon coolpix 31 is showing out of memory yet i believe there is plenty of capacity available pls help
door william sheehan
2 commentaren meer tonen
