one of the prongs came off
is there any way to replace it?
Is dit een goede vraag?
nishonijewelry , could not find the plug in a part listing, every body wants to sell the hole blower unit.
Are you feeling handy. You could have unit disassembled and have a pig tail and plug added. It would take a little ingenuity but can be done if you would like to go that wrought. Just make sure cord is attached/ fastened in body securely and can not be yanked out of housing.
Hardware store should have all required parts. 2 feet of 14-2 extension cord, 1 heavy duty male plug(if existing was 3 blade/terminal, replacement should be 3 blade) and a cable clamp or 2 that will work to secure wire from being pulled out of body of blower. You may also need 3 female spade terminals to clamp on wire to make the connection back on switch/motor. Link below is just to give a visual of what I am talking about. Good luck.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 16
Altijd: 1,039
