Why does my device's touchscreen not respond?
The touchscreen does not recognize any of the key that I press.
Is dit een goede vraag?
This problem may be caused by a faulty digitizer. Try tapping various parts of the screen. If the device is only registering commands at certain parts of the screen, registering incorrect commands, or not registering at all, then the digitizer may need to be replaced.
If the device's screen is cracked, then this problem may not be caused by a faulty digitizer. A cracked screen may indent the structure of the device and unintentionally apply pressure to the digitizer. To overcome this pressure, the digitizer will need hard taps. Normally, the digitizer will respond to soft taps. Replacing the screen may fix this problem.
Check out the troubleshooting guide on this device for more information: TomTom GO 500 Troubleshooting Guide
Was dit antwoord nuttig?
problem in the screen. Change the sensor. I had the same problem.
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 3,105
The screen will not activate when touched
door Dean Dotterman
The touch screen does not respond on the left side at all
door Dean Dotterman
