Can the LCD be replaced?
Is it possible to remove the bezel around the screen to access the LCD? If it is glued on, would a similar heat-gun method as needed for the recent Macbook Pros work?
Is dit een goede vraag?
to use a heat gun... see How to Replace the Macbook Air Hinges and LCD - heat can deform the rubber trim.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
Was dit antwoord nuttig?
Thanks! Sorry, should have checked earlier revisions of the Air line for the answer before asking.
No, the whole machine has to be taken apart!
lutris you can remove the bezel and change the led from that . i have also changed the led . see the link :
http://www.youtube.com/watch?v=eHNtnvzfS...
be patient thnx
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 5,501
2 opmerkingen
Can anyone tell me what the part number is for the LCD panel. I'm trying to find a exact replacement.
door weidyc
weidyc, it would work better for you if you click on the link on the right side of this page "ask a question" and give as much detail as possible. I also believe that the apple guru's always ask for the serial numbers...anyhow give it a try and I am certain you will get a quick response. Good Luck
door oldturkey03
