Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
Charging iPhone 4s problem?
My iphone 4s will only charge sometimes. I have to plug it in and out a bunch of times until it finally charges.
but when my phone shuts down and I plug it in once it will charge until it turns on and then the battery is not charging at all once the lock screen loads up?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
If you haven't already, firstly try another charging cable and / or wall adapter.
Those are all signs of a bad charging port. Replacing it should do the trick.
Where you can buy the part:
iPhone 4S Dock Connector
Guide to replace the part:
iPhone 4S Dock Connector Replacement
Replace a dirty, damaged, or corroded dock connector to fix problems with charging, connectivity, and USB recognition. Afbeelding
Product
$19.99
Was dit antwoord nuttig?
Score 3
if you're able to check the voltage of the battery would be helpful to know also. It could be the battery either needs a boost or is defective.
Voeg je antwoord toe
Steph zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 138
