How to remove stains from outside of the speaker?
How to remove oil stains from the sleeve or cover of the outside of the megaboom speaker
Stains appear to remain and not disappearing
Is dit een goede vraag?
oisinfog , Create a soapy cleaning solution by squirting dish soap(Dawn dish soap, or other grease-fighting dish soap). Hot water in a bucket of clean water and agitating until bubbles form. Hot water is ideal because it will help to dissolve the oil stain. Dip the sponge or scouring pad in the soapy water, start working on the grease stains.
For stubborn areas or to get tiny cracks or crevices, use the toothbrush,Change water and repeat as often as needed until the plastic is clean.
If very stubborn try making a baking soda paste with water and apply it to the discolored plastic. Let it sit and work for twenty or thirty minutes, and then clean the plastic with a moist cloth. Wash, rinse, and dry. Link below may also have ideas to try. Good luck.
Was dit antwoord nuttig?
To wash, use warm soapy water manufacturer recommends for cleaning.
I've washed mine with dishwashing liquid used generously under running warm water. That didn't remove the greasy oil spots completely, but at least they vanished a little and got brighter.
because the surface made up of soft material (rubber). Stains dont go away
i have a white one and a blue one. i have washed the white one 4 or 5 times using windex with amoania. ispray the windex straight onto the speaker then with a soft thoothbrush i scrub it then with a clean and dry white wash cloth i rub it . wash cloth gets very dirty. then again with another white cloth i dry it. ive had it for a little over 3 years and still works and sounds like new. hope this helps .
Does this still apply to UE Booms? Is this method you're using for a white UE? I have a white one and I've been searching for ways to clean it!
Hellow, how are you today?
Go to this tear down and check at 01.28min
Put the boombox at vertical, press gentile by anti hour and them the botton stain will easily go free.
You do not suppouse to use any clean soap or other chemical producs at all ok.
Repet at the other side.
Hope Thats help.
Grettings from Brazil.
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 41
Altijd: 23,785
1 Opmerking
Hope Thats help.
https://www.youtube.com/watch?v=Ib7IQfMC...
door Renato 23
