Ga door naar hoofdinhoud
The Kenmore Direct Drive is a washing machine by Kenmore.
kenmore top load washer model #110.298328011 will not start
I selected the wash cycle and my washer just started to fill and then it shut off and there is power going to the washer but it will not turn on and I do not know what the problem is with it?
Is dit een goede vraag?
1 Opmerking
ken. possible the lid switch could be faulty, I will search for some links for you to check out soon.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
ken. possible the lid switch could be faulty, faulty timer,etc, also check all wires and connectors at timer switch/main control and motor. If you are not comfortable disassembling machine and testing components have a good appliance technician have a look, diagnose and estimate repair. Check the attached links,instruction and guides, Good luck
https://www.youtube.com/watch?v=TBeymPFy...
https://www.youtube.com/watch?v=q82wD659...
https://www.youtube.com/watch?v=7STcI9xw...
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thank You So Much for the help....:)
door
Voeg je antwoord toe
ken johnson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 213
