Ga door naar hoofdinhoud
Repair guides and support for the 2nd-generation Renault Mégane, also known as the Renault Mégane II.
Why do warning lights stay on when engine is running
why do warning lights on dash stay on when engine is running
Is dit een goede vraag?
Score 2
1 Opmerking
Hi, Which warning lights are staying on?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Norman, see the attached links for various warning lights and why they may be on. In some makes a lot of warning lights may come on and stay on when battery is faulty or charging system fault if both are tested and found to be good, you will have to have a good technician have a look, diagnose and estimate repair. Cluster or PCM could be faulty and not communicating correctly to one another. Check the attached links,instruction and guides, Good luck.
http://www.autozone.com/landing/page.jsp...
http://www.precisiontune.com/our-service...
https://www.theaa.com/breakdown-cover/ad...
Was dit antwoord nuttig?
Score 1
Last week I am visiting at http://universalmotorcarslv.com/ they guest are best
Voeg je antwoord toe
norman rushton zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 1,659
