Ga door naar hoofdinhoud
2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
Backlight not working on display
The backlight to my macbook display isn't lighting up. I know I get video, because if I hold up a flashlight against the Apple logo on the back of the display I can see my login screen in the front. I was thinking it could be the backlight fuse, but I dont know where its located on the logic board?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hello Jstervil,
It may very well be the backlight filter. There is not a user replaceable "Fuse". The backlight filter is a soldered on SMD "surface mounted device" and will require microsoldering skills nd a lot of specialized equipment to repair. This, sadly, is not a DIY repair. Call around a few shops in your area and see who would be willing to take on that job. Get several quotes though as they could range significantly.
Hope that helps,
Holger
Was dit antwoord nuttig?
2 opmerkingen:
Thanks for the response Holger,
Would you happen to know and show me where the backlight filter is located on the logic board? Also, I'm guessing replacing the display will not solve the problem, right or wrong?
door
You are correct in that replacing the display will not correct the problem. I'm out of town at the moment so I don't have access to the board schematics.
door
Voeg je antwoord toe
Jstervil zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 186
