Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De nieuwste telefoon in de HTC One-lijn, simpelweg de HTC 10 genoemd, kwam uit in 2016.
Display replacement / fingerprint sensor
Hey I replaced the display, but the new display didn't come with a new fingerprint sensor so I transferred the old one and it doesn't seem to detect it. Has anyone had success transferring the fingerprint sensor?
Is dit een goede vraag?
Score 3
1 Opmerking:
The HTC one 10 that i worked on had a costume ROM which the home and fingerprint senor did not work until we had full assess to the Phone.
door Deel
Voeg een opmerking toe
4 Antwoorden
Filteren op:
Have you found solution after all? I'm getting exact same problem
Was dit antwoord nuttig?
The fingerprint scanner is part of the home button itself. A lot of people had success replacing this part. I have seen a few iphones (5s) which had screen replaced but the fingerprint scanner was still working.
1 Opmerking:
this is an htc 10 not an iphone 5s, they are very different.
door Deel
I have a theory, fingerprint sensor will only work with a genuine display part.
1 Opmerking:
Thats likely the answer, currently using an on screen home button to compensate, no parts suppliers seem to offer a home button or display assembly that includes a home button.
door Deel
It's confirmed, I've got another display part, this time directly from HTC, transferred old fingerprint scanner, all works fine.
4 opmerkingen:
Hey can I ask how you got the replacement display from HTC? Will they sell directly
door Deel
I've got it from supplier who's known for getting parts directly from HTC stock in the UK
door Deel
Could you please link to the shop? I need to replace the screen of my HTC 10 and would like to know it's a genuine display replacement. Otherwise I would need to find out via trial and error if it's genuine - which is quite the effort considering the low repairability of the 10 :/
door Deel
@Ivan Navi - Could you please link to the shop?
door Deel
Voeg je antwoord toe
Pete zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 19
Altijd: 2,265
