Ga door naar hoofdinhoud
High-end gaming laptops produced by Alienware (a subsidiary of Dell since 2006).
162 Vragen Bekijk alle
My laptop cannot power on.
My Alienware laptop cannot power on. No response after pressing power.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
derekseven you want to start off by checking the output of your AC adapter with a multimeter. If the output is correct for your model (you did not tell us which model you have) then you need to consider taking it apart and measure/check the DC in connector. Try and trace the power loss from there on. If you give us your computers model number we may find a more direct answer.
Was dit antwoord nuttig?
Score 2
ive got a similar issue , what model do you have??
cheers
Phil
Same issue with a r2 15 , gtx 980m. It stopped whilr i was gaming and didn t start back. Doesn t turn back on.
Voeg je antwoord toe
derekseven zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 239
