Why am I getting F06 error
Washer gets so far into the cycle and starts flashing F06. Sometimes at the begining, sometimes towards the end. Won't pause or cancel
Is dit een goede vraag?
Alice, Unplug machine for a minute and plug back in, this will reset the machine. F06 error is drive motor tachometer error, control not able to detect motor speed, machine shuts off.
Possible reasons for error damaged/loose/pinched/corroded wire harness connection check wires at drive motor to tachometer, motor control unit and central control unit.
You may want to call a good appliance tech. if the reset does not work for you, have them diagnose and estimate repair.
Check the attached link,instruction and guide from a ifixit colleague, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button.
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 26
Altijd: 2,413
