My ps4 is not turning on tho it fell on the floor
My ps4 feel on the floor like flat on the floor when I tried turning it on it won't on what should I do
Is dit een goede vraag?
There are 2 common things that cause it to not turn on after a fall. The most common is that it causes the joints between the APU and motherboard to crack and become disconnected. Here is a link that will give you some ideas that might work for that: PS4 beeps once then turns off
The other (less common) thing is the power supply. Most of the time if it's the power supply you'll be able to try to power it on once but then it won't do anything at all if you try again...no noises, no lights, etc.
I hope this helps...good luck!
Was dit antwoord nuttig?
I dropped my PS4 and when I plug it it it doesn't beep or no light turns on,I tried turning it on with the remote but that dissent do anything ,is there anything I can do even if I have to take it apart to try find the problem I will. If you know the problem with it can you please tell me
How are you ment fix it happened yesterday my son dylan was crying about it please fix it
My ps4 fell once plug charger and now it doesn’t cut on will you please help me
Please help me with my ps4
I dropped it now when I turn it on is gives me a blue screen saying error with system software but I can’t log into my account to update and when I try to log in it freezes turns off then turns back on and does the same thing over and over again I’ve rebuilt the database and everything it still does not work
@nonsonazz that is hard to evalaute until you open it up. Use this guides and take it apart. Check for loose wires and obvious broken parts. Let us know what you find.
My ps4 is not turning on at all it's dead did it overheat or something idk but need help
@youngmateo follow the link provided in the answer given by @tronicsfix
Also remove and reseat your PSU. It may have popped loose.
My ps4 turns on but don't show up anything on my tv
Try a different HDMI cable or unplug both TV and ps4 from wall socket and try again hope this helps
I threw my ps4 off the 3rd floor balcony and it still works golden
What did you drop it on a mattress
Ok my Ps4 dropped off my desk which is about maybe 4 feet high.. And When I try to turn it on is beeps once turns blue then goes right back off.. what do I do?
If you still have a warranty sticker on it and it has not been open you can call sony and maybe get it repaired under warranty, there is also a just repair solution for those that the warranty has run out. Hope this helps, as far as dropping it it has probably cracked solder joints, which require advanced technical skills and or equipment to be repaired sony offers this service.
My ps4 dropped but it wasn’t far and for some reason I can’t play game disc what am I suppose to do
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 51
Afgelopen 30 dagen: 281
Altijd: 61,244
8 opmerkingen
My PS4 fell my Son pulled my Lan Cable and it fell. It was like 2-3 feet that it fell. It goes on and just goes back and the white light shows and my Controller is off. It doesn't go on. So what should i Do??
door Ryan Davids
i droped my ps4but it come on and every thing but my tv its my hdmi ps4 slim
door Aayden Taylor
My PS4 fell from 2-3 feet and my controller comes on and the PS4 does but it wont got to the tv but the hdmi cord is plugged in everything is plugged in but i cant get it to work. So should buy a PS5 or by a new PS4 or just get my PS4 fixed plz answer for me thx. ( no cap smh lke crazy)
door Cardell Battle
My PS4 fell from like 3 inches It fell flat And went into rest mode and it comes on but crashes a lot and then goes back into safe mode
door Jax Trevino no
how to put back on the top of my lid to my ps4 cuz i droped it
door kerra
3 commentaren meer tonen
