Ga door naar hoofdinhoud
4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
iPod Touch 5th Generation
So the problem with my iPod is that it won't charge like for example ur battery is at 20% it would stay there it won't charge at all I don't know if it is my charger or its my iPod
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi,
Without knowing more details about your ipod (if you dropped it, spilled water on it, bent the charging port etc), these are my suggestions:
The first thing to try would be a different charger and a different outlet, to ensure that those are not the culprits.
Batteries do have a limited life span; after a certain number of charges (~2000) they will start to fail until they eventually can't hold a charge anymore. You could be due for a battery replacement. This guide, up through step 16, outlines how to do this.
iPod Touch 5th Generation Logic Board Assembly Replacement
You could also have an issue with the charging port, a replacement is outlined here, through step 27.
iPod Touch 5th Generation Rear Case Replacement
Good luck!
iPod Touch 5th Generation Logic Board Assembly Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
1 - 3 hours
iPod Touch 5th Generation Rear Case Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
Was dit antwoord nuttig?
Score 5
1 Opmerking:
Great answer! You need some more rep!
door
I think you should check your charger on another apple device to see if it charges that and if it doesn't its not your ipod its your charger
1 Opmerking:
This has already been resolved and accepted.
door
Voeg je antwoord toe
Zubair zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 187
