Ga door naar hoofdinhoud
The HP LaserJet 1200 is a monochrome laser printer produced by Hewlett-Packard.
10 Vragen Bekijk alle
USB Printer Port to connect to computer is not working
The printer works but the power between the printer and the computer is dead. I am certain it is the USB Port Prongs that are the problem. I have tried several other cords and still get the same outcome: nothing. Can I simply change out this port? Where can I buy this port replacement? Many thanks!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Can you tried an USB-HUB? If not, try to use a USB-HUB to try at first.
Was dit antwoord nuttig?
Since your USB port appears to be non-functional, I suggest switching over to printing via the network, print server, or WiFi using the HP JetDirect port. You may need to purchase something extra to get this to work, but is easier than resoldering a USB port.
Voeg je antwoord toe
Katharine Atchley zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 510
