Ga door naar hoofdinhoud
Vraag afgerond
White Screen Tried restore reset and jailbreak
Hey:
So I had a broken iTouch 2G
Bruised LCD
Cracked Digitizer.
I was able to open it
and replace all the parts
Everything worked fine
I tested it before closing it
So I go ahead and close it and when I boot it up I got a White screen
I've seen and dealt with this problem before
So I tried to restore it. Nothing.
I tried to Jailbreak it. Nothing.
Downgraded. Nothing
Reset.Nothing
Restore DFU.Nothing
Different LCD. Nothing.
I actually tested the same LCD.
And it works fine.
The digitizer works fine aswell.
I can slide to unlock and power off
but the screen is just white.
Is there something else I haven't tried?
Im draining the battery now and
reinstalling everything in the morning.
I've read that low batteries give white LCD errors.
How long should I wait? 24 hrs?
Any Advice or 2 cents may help.
I also checked the mobo for burnt
components thinking that I shorted something. No luck.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
If you've already tried replacing the LCD (and tested your old LCD on another device and made sure it works), then you're going to have to replace the logic board. If you can actually get the device to respond (you said you could slide to unlock and power off ... when the screen is white?) then it's probably not a software problem.
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,879
