Power but no sound on tv on my 55 inch
I have a 55 inch led hdmi digital TV and the volume turns down by its self , and remote doesn't work when the TV does this . I tried to use the buttons on the tv, but that did not work . I also tired unplugging and holding the power button on tv . That seemed to work temporarily, but then it happened again . What can I do to fix it ? Please help. Thank you.
The model number is fw50d36f.
Is dit een goede vraag?
5 opmerkingen
what do you mean by volume turns down by itself, like you can see the dialog box and the volume going down or just no sound?
door echow2001
Hi,
Try taking the batteries out of the remote and see if the problem occurs. You may have a sticking Volume down button in your remote.
door jayeff
The dialog is up in the left corner and u can see it going down fast . I did think the same thing about the remote but I took out the batteries n turned the TV up with the bottom on the TV a few minutes later it was at 0 .
door Carolyn Brandt
@cookiemonster38 sounds like a bad button board. the problem is going to find a replacement.
door oldturkey03
Thank u all for ur helpful hits I am going to try the button board n see if that fixes the problem
door Carolyn Brandt
