Ga door naar hoofdinhoud
The Sony Xperia Z5 Android smartphone was released in October 2015. The Sony Xperia Z5 features 5.2 inches 1080 x 1920 pixels display and is equipped with a Qualcomm Snapdragon 810 processor alongside 3GB RAM and a 23 MP rear camera.
74 Vragen Bekijk alle
Replacing cracked front glass
Hello guys. Cracked my screen yesterday on my Sony Xperia z5. My LCD is just fine, touch screen is not working properly, proximity sensor also freaks out and of course the glass is cracked. I wonder can I replace only glass and touch panel something like that: https://www.amazon.com/Sony-Xperia-Digit.... Or I need to buy a full LCD replacement? Also I've seen replacement videos on youtube but I don't have a heater gun so can I somehow avoid this tool?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Alexander Zhurkevich the glass only repair will require you to separate the old glass from the LCD. After that you will also have to have the right adhesive and tools to re-adhere the glass. Unless you have the right tools and lots of practice, the chance to get this done are slim. I suggest that you replace the complete assembly since that is an easier and more successful option. You do need a heat gun to remove all the adhesive. Sometimes a good haird dryer is enough, but you will need something.
Was dit antwoord nuttig?
Score 2
Don't even bother trying.
Just replace the whole display.
If you go down the loca route you're gonna damage the backlight. You can put no OCA between the middle and it will work but it will be a poor repair
It is easier to just get the full LCD
Score 1
Voeg je antwoord toe
Alexander Zhurkevich zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 1,812
